- Thu Mar 14, 2013 2:34 pm
#328580
So I have the D16z6 and I noticed that the compression ratio is lower than most 1.6l's.. I would like to bump it up abit.. As far I i can remember you can use the y8 headgasket.. Does anyone know how much this would gain me.. or if there is anyother headgaskets that could be used.
- Thu Mar 14, 2013 4:16 pm
#328582
Not enough to notice anything..
- Fri Mar 15, 2013 3:08 am
#328645
Put on a y8 head when you do the y8 headgasket and you'll notice a difference.
- Fri Mar 15, 2013 4:07 pm
#328665
Ok cool.. now i was just oging through the mini diy thread.. and i noticed it saying it could yeild 10.5:1.. now is that with using the 1.5l block or would i get the same with the d16y8 block.. Seeing as the rest of the internals are basicaly the same, The exception possibly being the shape of the pistions.
- Fri Mar 15, 2013 4:40 pm
#328668
Correct, that was with the d15b7 bottom end. If you use a D16y8 with a D16y8 head, you'd be back to the stock CR, which is 9.6:1
There's so many combos of D series... someone has made a compression calculator
http://www.knology.net/~jediklc/D.htm
TOPIK3900 wrote:Ok cool.. now i was just oging through the mini diy thread.. and i noticed it saying it could yeild 10.5:1.. now is that with using the 1.5l block or would i get the same with the d16y8 block.. Seeing as the rest of the internals are basicaly the same, The exception possibly being the shape of the pistions.
- Fri Mar 15, 2013 8:10 pm
#328678
The Y8 and Z6 head gasket are the same. They were once different, but they were consolidated.
On the internet, old information never dies.
