- Tue Aug 19, 2014 6:02 pm
#348019
So I jus got an eg hatch with a check engine code 21 for vtec spool solenoid. Its the d15b8 non vtec. I kno u can pin for vtec. Is there anyway to I guess u could call it de- pin vtec.
Just get the right ecu for the D15b8, the P05. They're dirt cheap.
What ECU do you have right now, P28? The P28 uses a 4-wire o2 sensor while the P05 uses a 1-wire o2 sensor (except for cali cars maybe).
So if you have a 4-wire o2 sensor, you'll have to downgrade to a 1-wire if you use the P05 ecu.
