- Fri Oct 23, 2015 2:57 am
#357012
I have 1997 that I got the guy parked it last winter and just got it today so like a year it was sitting .. it needed a battery ok check did that car cranks extremely slow found it was that starter ok check changed that, car cranks faster and sound like it's just about to start sounds better then b4 sounds like it wants to start like it almost there... any ideas I check spark with the plugs 3 of them were blue spark 1 was a orange color.. any ideas weak spark maybe ? ? Please any insight Will help I wanna fix it tommrow ...
- Fri Oct 23, 2015 2:36 pm
#357129
English ?
- Sun Oct 25, 2015 3:08 pm
#357160
Anyone ?
- Sun Oct 25, 2015 7:08 pm
#357161
Do a basic tune up. Make sure that the cap and rotor aren't corroded. Drain the fuel tank and put fresh fuel in. Make sure ground are clean.
1992 Honda Civic SIR-S
- Mon Oct 26, 2015 4:03 am
#357168
New distributor new starter fresh full tank new spark plugs and still cranks likes it's about to start and nothing.... any have any similar problems
- Mon Oct 26, 2015 1:22 pm
#357210
Verify mechanical timing. Verify fuel pressure. Make sure you have the wires on the cap correctly.
- Mon Oct 26, 2015 2:52 pm
#357212
What is the firing order for a 97 civic D Series non vtec I can spray starting fluid in there and it doesn't even kick over it wants to but it doesn't start
- Mon Oct 26, 2015 3:17 pm
#357216
How long are you cranking the motor for when trying to start it?
I had a 96 civic that sat outside for a few months one time and it was not starting, everything was correct on the engine. Finally I put jumper cables to another car and cranked it for like 30 seconds straight and it slowly started to sputter more and more, until it finally fired up. Then it ran & drove fine and never gave me that problem again.
- Mon Oct 26, 2015 3:59 pm
#357218
I tried that but I only tried cranking for 15 seconds are so cuz I didn't want to fry the starter the new starter I put in I mean it's getting air fuel and spark its just got me totally confused what killed it was sitting outside for so long
- Mon Oct 26, 2015 5:01 pm
#357219
Also I've tried to pop start and it didn't work either
- Tue Oct 27, 2015 3:34 am
#357231
- Tue Oct 27, 2015 5:14 pm
#357248
It ran when he parked it right?
Pop start isnt going to do anything if it isn't firing up. I'd replace plug wires & Be sure firing order is correct and try cranking it longer, especially if it starts to studder as you're cranking it.
This is assuming everything else is correct and the car was running fine when parked.
Also, have you drained & put fresh gas in it yet?
