#52450 ok heres the deal, got the engine in but when we turned the key the lights went on and the wipers, tried to turn the car over there was a click and everything went off, now nothing works atall, were still getting power to the ecu but we dont knw if the powers cummin out but theres no ignition lights or anything. Anyone know what might have caused it ?
#52451 Have you checked your fuses? and have you done any work recently?
#52452 checked the fuses and by work what do u mean ?
#52456 Battery?
By KRYSTED9354
#52465 BATTERY FUZE ?? and did u put turmenod right + on + and - on - on battery ? LOL
LaMbErT* wrote:by work what do u mean ?
I meant have you worked on your car recently. I must have spaced out and not put "on your car" in there.
All of the above is good ideas.
By Graham
#52489
Lamberts cars been in bits for about 3 years :P
that's plenty of time for a battery to go bad
#52750 Checkd battery and its got full power and checkd connections and they seem to be fine
#52840 with the battery in and car off/key out, will the headlights stay on or will the battery die after a few mins?
Or it sounds like you could have a short which is always a pain to find...
#53047 ya see i recon theres a short and if there is i really aint got the money to get an auto electrician to have a look at it :(
#53533 bumpty bump
#53549 I would start double checking all your wiring that you modified or removed from the car when you restored it.
long boring process, been there a few times. :(
#53598 cheers mate ill try alotta people said about the earths but ive checked em all :cry:
