By Jadori
#71071 have put on an intake before..so i got my intake today and i got my throttle body spacer..so i swap out the gasket on the throttle body and put it back on(i didnt put the spacer on) i put my intake on and turn it on and it now idles at 3000..i dont know what happened i checked my lines i even tried adjusting the throttle cable i got nothin...this car has a piece of shit since i got it!!!!!!
By 95projektvic
#71074 adjust the throttle position sensor.....i'll try and find a picture of it....unless someone and get that before me
By Benj
#71076 need to clean you idle air control valve ( i think thats what its called ) its located under the t/b has a hose going into it and coming out from the intake and going back into it, there are 2 lil screws that you will have to take off and then adjust the white cap, in or out, till it idles better
#71090 You didn't clean off the old gasket and/or tighten down the throttle body correctly and evenly. Or you didn't install the new gasket properly.
By Jadori
#71095 ill try all that..ive cleaned my iacv about 2 weeks ago..but ill do it again
By Jadori
#71439 ok i went through all that and the solution was the gasket..the hole on the gaskets that came with the spacer were way bigger than the oem gasket..that sucked..i hate spacers! :x ...lol
By 95projektvic
#71449 glad it worked out for you. :thumb:
By Jadori
#71452 thanks me too
