By misir00
#113640 the hose is all the way in but its still leaking from the part where it connects
i dont know if i have a different rad but mines shifted to the right
and its the hose all the way on the bottom
By Dippin_EG
#113749 It could be out of round, That happened to me and i just got the screw type hose clamps and put 2 of those bitches on. No more leak :thumb:
By JUICE
#113752 just change the damn hose. you want that thing shittin out goin down the highway?? if its on tight and its leaking...... change it.
By Dippin_EG
#113761 Changing it would be the best option, However, If its not the hose and its the outlet/ inlet being out of round, a second hose clamp will suffice. Or you could round it back out with like something circular.
By misir00
#113894
Dippin_EG wrote:It could be out of round, That happened to me and i just got the screw type hose clamps and put 2 of those bitches on. No more leak :thumb:
yea everyone that looks at it tells me to use those screw clamps that tighten when you tighten the screw
everything is fine it just that it still leaks when the hose is on
By d-mon
#113896 change it.
sometime the clamps 'bite' through the hose and make it leak
By CivicSiRacer
#126129 Could be one the part where the hose clamps onto the radiator is cracked. I know mine was when I got it home from the buyer.
But yeah easiest thing and safest is to change it. Drain the coolant, take old hose off, put new one on. Should take only 10 mins. Just make sure coolant is cool (car should be off for at least 2-3 hours).
By misir00
#126528 yea i fixed it a while back but what happened was where the clamp squeezes onto the hose it bit through and it leaked through there so i cut that part off and reconnected it
