By ljonboy
#115008 right now i have a y8 block with a z6 head. may have ruined my Y8 head because i am not sure which head bolts to use Y8 head bolts on the Z6 head??? all Z6 bolts is not right. and i can get a Y7 Block so do i fix the Y8 or take the Y7 and if so do i use Y7 head bolts or then the Z6 head bolts???? thanks for the help
By JDM-Z6
#116367 i go with the y7 block cause it is non vtec thats what i have and am runnin harder then a y8 block
ljonboy wrote:right now i have a y8 block with a z6 head. may have ruined my Y8 head because i am not sure which head bolts to use Y8 head bolts on the Z6 head??? all Z6 bolts is not right.
using the wrong bolts wouldn't have ruined the head, but it may have stripped the block. I've never put a z6 head on a y8 block so I can't say 100% sure which bolt combination is correct.
By drago742gtr
#116572 i have a y7 with a z6 head , get arp head studs and you can use all but one bolt , someone said to use a z6 head bolt by the vtec solinod but i just used all of the arp head studs and mine is runnin fine just make sure u torque them right
