B16, B18, B20
By 92dxeg
#180142 Ok here is my prob my motor is all in my hatch but there is a lil prob
it keeps stailing and will not idle just stalls unless i hold the gas then it will idle untill i let go of the gas
now it will idle when i pull off the hose that goes to the pcv vavle and it will idle. but when i put it back on it chokes out.
i change the tps also i tried my iacv on my cuzin b20 and it worked
i did run the cel and it was number 19 auto trans lock out. but even if it was an auto comp it should idle right??? plz help
By Classiccarsrule85
#180241 Ok if your running a b18a1 and your running the a1 intake?? then you may be missing the vaccum sensor the black sensor on the intake manifold. that connects to teh vaccum chamber near the battery.....
but this sounds more like what happened with my buddies car the vaccum chamber near the battery where there are 3 lines well the bottom popped off and it would run only when the gas was depressed so yea you more then likely have a leak....
By 92dxeg
#180242 no iam not running the a1 intake manifold i have a b1 manifold but iam running a a1 tb with out the fitv vale cuz the kid did not give it to me when i got the hole swap do i need this
By 92dxeg
#180509 well i think i fould the prob i need a 94-95 integra throttle body that has the fitv monted on the bottom the DA one i have will not work cuz it mounts to the intakemanifold and i have a DC intake manifold
