B16, B18, B20
By garrrymac
#241094 on a b16 does anyone know if the thermostat housing and water housing (with the coolant bleed valve on it) have proper actual gaskets that you can buy for them? i asked at honda and they said no and i was to use instant gasket, iv done this and now there both leaking. my local honda dealer is pretty useless for getting parts from tho and i find it hard to believe theres no proper gaskets for them. if this is the case tho whats the best instant gasket to use? i used locktite stuff but its obviously pish
By blk92hb
#241253 there is a gasket for the thermostat but not for the housing, and the one with the bleeder screw use hondabond or gray sealant.
other than that there is no gasket. if you want you can look at this site for help with gaskets and other parts.http://myhondapartsstore.com/
