- Tue Apr 03, 2012 12:11 am
#300724
make sure your MAP and TPS sensor or plug in the right place. MAP can cause you to bog upon acceleration alot with TPS. check those and get back.
and There is no code 24 if i remember correctly..
1 – O2A – Oxygen sensor #1
2 – O2B – Oxygen sensor #2
3 – MAP – manifold absolute pressure sensor
4 – CKP – crank position sensor
5 – MAP – manifold absolute pressure sensor
6 – ECT – water temperature sensor
7 – TPS – throttle position sensor
8 – TDC – top dead centre sensor
9 – CYP – cylinder sensor
10 – IAT – intake air temperature sensor
12 – EGR – exhaust gas recirculation lift valve
13 – BARO – atmospheric pressure sensor
14 – IAC (EACV) – idle air control valve
15 – Ignition output signal
16 – Fuel injectors
17 – VSS – vehicle speed sensor
19 – Automatic transmission lockup control valve
20 – ELD – Electrical load detector
21 – VTEC spool solenoid valve
22 – VTEC pressure valve
23 – Knock sensor
30 – Automatic transmission A signal
31 – Automatic transmission B signal
36 – Traction control found on some JDM ecu’s
41 – Primary oxygen sensor heater
43 – Fuel supply system
45 – Fuel system too rich or lean
48 – LAF – lean air fuel sensor
54 – CKF – crank fluctuation sensor
58 – TDC sensor #2
61 – Primary oxygen sensor
63 – Secondary oxygen sensor circuit
65 – Secondary oxygen sensor heater wire (black wires)
67 – Catalytic Converter
71 – random misfire cylinder 1
72 – random misfire cylinder 2
73 – random misfire cylinder 3
74 – random misfire cylinder 4
80 – EGR Valve/Line
86 – ECT sensor – Cooling System
91 – Fuel Tank pressure sensor
92 – EVAP Solenoid/Valve/Vacuum Lines
