- Sat Dec 25, 2010 7:07 pm
#229808
Perhaps the fuel pumps are priming, and the fuel pressure is enough to keep the engine running for the 2 seconds you described, but the fuel pumps cut off when you let the key come out of the start position.
Just a guess. I've seen it happen once on a stock DC4, but not since then.
Also, do you have a wideband O2 sensor? If not, Hondata is running off of the narrowband that came in the car stock. It might not be reading properly, but still not throwing a code. Make sure the lambda sampling on the s300 is set to narrowband, too. Hondata has an autoprotection mode if it sees that the engine is running in an unsafe manner. I'm not sure if it will shut the engine off but it will cut the fuel temporarily. It may cut the fuel long enough for the engine to shut off at idle.
