- Thu Sep 05, 2013 4:13 pm
#336372
here is a pinout for the ecu
http://www.ff-squad.com/technet/wiring.obd1.htm
is the ecu chipped or modded in anyway??
for the injectors it would be best to take them to a shop and let them test it or replace them with a set of ones you know is ok or try yours in another car if thats possible.
my bet is still low pressure but im not always right
here is some info for them also.
http://www.hondata.com/techduty.html
also remember to clear the codes by removing the - pole or the backup fuse for few sek.
you can also try cleaning the v-tec solinoid, there is a filter inside that can be dirty, and if you do the butterfly trick i posted before and that gets you no cel then there something wrong with the oil sending unit or wiering on the solinoid.
