B16, B18, B20
By Coplies
#151251 So i have a stock d15 in my eg8 and i am looking to do a swap when i get the money. I want to get a b18c and i have a few questions. First, do the b series engines support a/c, cruise control and power steering? Second, would a 6 speed tranny fit/ would it be worth doing? I was wondering if the 6 speed would allow me to get better mileage or if it just makes the gears closer together. Last, does anyone have a link to a good diy on a b swap?
Thanks guys
By egsedanguy
#151256 well some stuff lke power stering should work. but for ac you would need a bracket off a del sol.. and the swap is pretty strait forward. bolts right in and you can use your harness, just have to add the v-tec wire and like 1 more.. as for a 6 speed they dont make one. gsr tranny or a b16 tranny would be your options for good trannys. if you buy a full gsr swap then you would just drop the bitch in and have fun..
By Dubcity-EG
#151342 You need to wire in vtec, vtec pressure switch, 4 wire 02 sensor, Iab, and knock sensor.
#151372 Yes, you can keep AC, PS and cruise. You will need however to get a Delsol VTEC ac bracket to retain your stock D compressor.
By Coplies
#151594 Ok cool, thanks guys. So people who have done a b18 swap, about how much am I going to have to save to be able to do this right?
By Classiccarsrule85
#151602 depends really im about to get a sweet deal on a ls swap from my junkyard that i pulled for around 3-400 but pretty much unless you know people your gonna have to order online and that normally goes from 1ooo on up from there plus shipping......but yea just depends really my swap is something rare and youll be lucky to find it that cheap.
#151621 Gsr swap will be around 2500 to 3000. COmplete swap.
By Coplies
#152193 hmmm...ok. Thats about what i figured. Where would you guys recommend looking?
By Weaksos
#152764
egsedanguy wrote:hmotors.com i here good thing from them..
x2 on that so the p.s. bolts right up?
By egsedanguy
#153125
ya p.s. should be fine nothing really diff on that.
By Coplies
#153363 Also, i know that you are supposed to get the axes out of an integra. Will the axes off my d15 fit? They are brand new
#153364 well im pretty sure thats a no im not sure about the passenger side axel but i know the drivers side is definately different.....since there is a intermediate shaft on the drivers side.....
By That One Dude
#153370 No, you have to get the B-series axles for the swap. There's no way around it unfortunately.
By egsedanguy
#153377 ya you need axels, half shaft, shift linkage, throttle cable( when i did my b18b swap i was old to use my stock cable witch was way to short so i had to use the teg one),ecu, motor mounts, harness. if you get the full swap online then it should come with every thing you will need...
