B16, B18, B20
By KingcoupeO
#155660 only once the car heats up the idle jumps between 8 and 11 rpm anyone ? :? sounds like a high lift cam ...but it def doesnt have one .
By KingcoupeO
#155670 i gotta short ram intake stock manifold .. i will check the map
By Tristanw10
#182607 I have the same problem with my b16 swap
By 99cx
#182625 im telling you guys. clean your FITV valves!!!! haha
it willllll work :thumb: :thumb: :thumb:
By ExCoupe94
#182644 or the pcv!!! put the clamps on the vacuum line next to the one leading to your fuelrail (visegrips ftw!!!) if it fixes the prob tis the pcv.
By Tristanw10
#182743 I have tried the FITV with no luck, which hose are you talkin about, could you post a pic of it or a detailed location, thanks
By ikon
#182809 how bout the idle air control valve......... its on the back of the manifold next to the firewall. two 12mm bolts :D
By Tristanw10
#183056 Tried that too, cleaned it out and tested it with a scan tool, no luck..
