- Sun Feb 07, 2010 2:21 am
#173819
The only two plugs would be for vtec....
every other engine harness dx,cx,lx, etc non vtec civic motors should all have there place on the ls motor.....depending on what year the 96 on up do not have the vaccum black thing.....
and the civic harness
well some of the plugs need to be extended and that might be why you have plugs hanging around the bay.....
1980 volvo 242
2001 crv
2001 crv
- Sun Feb 07, 2010 3:03 am
#173825
what dose the plug look like and what ls motor are you useing????
as far as i can tell you may either have a broken sensor on the head or something isnt right......was the harness you got from a auto or 5spd.....
also im not too sure what plugs you are talking about because there should be a temp sensor near the thermostat ummm if you read my wireing harness diagram i made up from a 92 civic dx that should help you out quite a bit.......
heres a link....
http://civic-eg.com/viewtopic.php?t=12066
heres a link....
1980 volvo 242
2001 crv
2001 crv
- Sun Feb 07, 2010 5:21 am
#173858
well near the dizzy everything should have a plug i do beleive ill check tomarrow on my z6 to see...but the one near the thermostat im leaning toward that being your engine temp sensor since most 90-93 integra motors have their temp sensor 2 prongs on the back of the block near the oil sensor....best bet would be to either extend that plug and use a 88-91 civic or 90-93 integra temp sensor plug.... or get a thermostat housing i think the d series may work not completely sure about that but yea get a obd1-2 thermostat houseing and that will have teh engien temp sensor in there that way you wont have to extend anything....
but yea im not sure how the 93 integras since i think they where obd1 had things set up completely since it was still the old chassis but yea i will check tomarrow for that plug under the dizzy if you coul get a discription for it or look at that list and look near where the dizzy plugs are because i did it in pretty much order of where the plugs are on teh harness and get back with the colors etc...
1980 volvo 242
2001 crv
2001 crv
