B16, B18, B20
By 92dxeg
#177180 Now i have been trying to get my swap done but i have a problem and any insight would be helpfull.
ok noy my car wont idle it will just cut unless i hit the gas. but as soon as i take my foot of it dies i just changed the throttle body still the same thing help plz :?
By elrompetoto
#177191 Ajust the cabel both at the tb and at the pedel if its still not ideling then there is a skrew on the tb where the cable connects ajust that.... that skrew is a bitch 2 losen so do this is the ajusting dose not work good luck
By 92dxeg
#177215 ok i will try that
i was thinking that it could be one of the sensors like the ivac,map,tps sensor cuz i have an extra sensor by my battery.
also when i got the harness it did not have the plug for the ivac so i took it of an old harness. but the plug for the ivac and the air intake temp sensor are both the same plug i dont no if i have them in the rights spots if any one knows the colors of the ivac wires and the air intake temp. the would help big time
By elrompetoto
#177226 Go 2 the diy there is a guy who broke down the hole wire harnes 4 an eg ull find the info of with plug gose where there I can't post the link becouse I am using a cell phone
By 92dxeg
#177369 He thanks for the insight so far i was jw could this be a problem if i dont have my wire harness grounded to the fuse box ??
By elrompetoto
#177431 I DONTKNOW DO U HAVE A CDL CODE
By That One Dude
#177630 The throttle cable wouldn't have anything to do with whether or not the engine will idle.
If you actually ever look at the throat of the TB, you'll see a hole about the size of your pinky. That's the idle bypass hole. When the engine is idling, the throttle plate is fully closed. No air flow.
The IACV has a poppet valve in it that meters and measures the air flow at idle.
On the aft side of the TB, there is a brass screw. If you're looking at it as if to look down the throat, it will be at the top left corner. It might be covered by grey paint. Scrape it off to reveal the brass screw.
With the engine off, screw it down all the way until it stops, but don't let it get tight. It's a bitch to break it back loose. Back it off two full turns. That's where it should be as set from the factory.
If it still won't idle, and simply cuts off, check the throttle position sensor with a voltmeter a paper clip. Connect the common ground lead (black) of the VM to a bare metal bolt, or to the VC ground. Insert the paper clip into the back side of the middle wire on the connector for the TPS. Attach the hot (red) lead to the paper clip. Put the key in the ignition in the ON position. Read the voltage in the closed position. It should be 0.45v +/-.02v at 0% throttle. At WOT, the voltage should be 4.5v +/-0.1v.
If the voltages are good, go ahead and replace the IACV.
Forgot to ask, do you have any CELs?
BTW, I got that from the factory maintenace manual for the 1994-1995 Acura Integra (OBD-I). Since you have a B, all of the TPS voltage values are the same across the B spectrum.
By 92dxeg
#177636 ok guys thanks so far i have an update tho
just for shits and giggles i pulled of the pcv hose thats in the intake manifold. and turned the car on and it idled and when i put my foot on the gas then it stalled but when i swap the motor i put in a pcv vavle in it what else could it be
By 92dxeg
#178077 now if there is a vaccum problem could it have the same effect if i pulled of the pcv hose and it idled fine do u think thats the problem
By That One Dude
#178085 I don't know without actuallly being there messing with your car...
By 92dxeg
#178180 ok thanks for all ur help i willl keep u posted
By 92dxeg
#178631 so pretty much what ur saying it eather has to be the throttle screw,iac, or tps sorry have not had time to work on it too much snoww
By That One Dude
#178800 Or it could be the FITV (fast idle thermal valve), MAP sensor, vacuum leak at the throttle body, or the manifold flange, or any number of other places.
Get a can of starting fluid (yes, it's actually called starting fluid) from your local auto parts store and spray it all over the intake manifold and throttle body mating surfaces, all over any vacuum hoses, and where any other gaskets could have gotten effed up, or broken causing a vacuum leak.
By 92dxeg
#179606 ok guys i have an update i ran the cel
and it was number 19
auto trans lock out and the ecu was giving to me could this cause the prob that iam having with no start
any insite would help thanks guys :lol:
By 92dxeg
#180140 any body ever had this prob
