- Thu Mar 18, 2010 7:57 pm
#182124
I have a 94 civic lx with a b16a swap running a p30 ecu, my speedo doesnt work all the time and i have no vtec. Can anyone give me a clue as to how to check and see if my gauge cluster is bad?, the d series i had in it had the same problem so i know its not the vss, thanks in advance.
- Fri Mar 19, 2010 12:58 pm
#182268
agreed... and like chance said try subbing it for one you know works
JUICE wrote:most likely the cluster
PANDA CREW No.20
PANDA CREW No.20
- Fri Mar 19, 2010 3:15 pm
#182301
check wiring from vss to the speedomoter with a volt meter, if vtec won't engsge that means your ecu isn't seeing any speed from it.
