B16, B18, B20
By jdmpipedreamd16
#187655 ok so i know its not the motor making my car shake so i thought id see if anyone else has or had this issue. when i acel. past 2500rpm's i get a hard shaking my door pannels dash and all i dont know why pzl help. i did add a aluminium avid solid mounts to replace the p/s and a/c mounts maybe thats it but i dont think it is. by the way im running a 92 eg 4dr w/b18a1 mated to a jdm b16 transmition 5speed. :? :?
By LX_Sedan
#187658 Does it shake at high speeds 50+ or all the time? Its more than likely the mounts but could be your tires, it one has a bump.
By forcefedEG
#187660 check your tires fist for air pressure and balance and make sure there are no knots in the tread... then do a full bolt check on your front end, axle nuts and lug nuts first! honestly id check your lugs before you do anything else :thumb: if not your solid mounts may be to blame but i have never heard of this complaint from something like that before :? hope that helps
By jdmpipedreamd16
#187860 its def. not the wheels and tires i just got brand new firestone firehawk gt's mounted on 91 crx si wheels so those are ok. and no its not a speed shake it only happens on accleraition like under 3000rpm's as it pulls past 3200rpm's it stops untill i upshift and the rev's drop under 3000 im gonna go bolt to bolt on my entire front end thanks for all the help :thumb:
By forcefedEG
#188149 dose it do it at that rpm in every gear? or just a certian gear or a certian speed at that rpm... jw?
By forcefedEG
#188213
jdmpipedreamd16 wrote:it verys but i found out what it is i need new door inserts
? like in your door pannels :?
By That One Dude
#188686 I have the Hasport 85A durometer engine mounts, and I have the same vibration around 2000-2500rpm. It's normal for the B18B1 (and probably other B-series...but I have no idea...) as far as I'm concerned. My last Integra did the same thing with the Hasport mounts.
