B16, B18, B20
By itCouldgeTwoRse
#203183 ok so i have myself a obd0 b16a. runs great pulls hard blah blah blah.
my issue is while im on the highway for about 15-20 minutes at a constant rpm it starts to bog down and mis fire until i hit the gas harder and it clears up until i keep it a constant rpm again.
i am throwing code 9 (cyp sensor in the dizzy) and the only way (or so ive come to understand is replacing the dizzy
would that be the cause of my boggin highway issue? i dont want to spend 275 dollars if i dont have to on accout the car runs perfect city wise and any other time.
or could it be related to the iac valve?
By JustinLeexxx
#203194 yeah Obd0 dizzys, are known to go out like crazy!
Ive had that same problem, I replaced the dizzy and it fixed the problem. however I went through about 3 more dizzys in the span of having a obd0 b series. lol
I'm sure replacing the dizzy will fix your problem!
make sure do check your distributor cap for cracks as well =)
