- Wed Sep 22, 2010 6:46 am#214902
Yes you can. That's the setup I'm going to be running in mine. But obviously ur going to have to use the LS rods and pistons as well.
- Thu Sep 23, 2010 10:52 pm#215129
Not trying to criticize let me just put that out there.
But I honestly never knew that! U really do learn something new everyday!
- Fri Sep 24, 2010 6:54 am#215185
I know that, but I never knew that you cud actually use "example" a b16 piston on a ls rod u know wat I mean. I thought u wud have to buy a b16 spec ls piston
- Tue Sep 28, 2010 5:18 pm#215750
If they are the right style for the rod I guess they would go on just fine. I havent delt too much with aftermarket pistons.
- Fri Oct 01, 2010 5:35 am#216184
you can put gsr pistons in the LS, but you still need to use the LS rods. LS, GSR and B16a all have different length rods to along with the different strokes they each have.
- Fri Oct 01, 2010 6:28 pm#216269
Put the LS head on the motor. all you are doing is swapping pistons. Though I dont think you really want to put CTR pistons in a LS. The pistons will stick out of the block and you will have a CR of 13.1:1. Stick with B16a pistons. or even ITR or GSR.
