B16, B18, B20
By jtdyer2004
#222930 i have a 93 civic dx with a d16y7 p28 ecu and i was wantin to do a b20 swap can someone give me a list of parts and the years i can find the parts maybe cost if you know about how much it will cost thanx
#222983 Cost depends on where you get your parts
Part list as with any B Series in an eg
- Complete B Series Engine(in this case b20)
- 94-01 B Series Hydrolic Transmission (b18c GSR and b16 Recommended)
- 94-01 Acura/Honda Integra Mounts(side and rear)
- 94-01 Acura/Honda Integra T Bracket Unless Delsol, then you need Delsol VTEC rear T Bracket
- 94-01 Acura/Honda Integra/99-00 Civic Si(em1)/94-97 Delsol VTEC Throttle Cable
- 94-01 Acura/Honda Integra/99-00 Civic Si(em1)/94-97 Delsol VTEC Axles
- 94-01 Acura/Honda Integra Shift LInkage
- 94-95 Acura/Honda Integra LS Ecu
- 92-95 OBD 1 Fuel Injectors, Integra/civic/delsol/cr-v injectors are the same As Long as its obd1 its good.
- 92-95 OBD1 Dizzy(Rewire b20 dizzy obd1, or get an alternator for a 94-95 Integra)
- 92-95 OBD1 Alternator (Reuse your D Series alternator)
If you want Power Steering, or A/C you will have to get the B Series mounts for them. 97-00 CR-V Power Stearing mounts will let you reuse your d Series power steering pump. On A/C you will need to look up what you need.
#222985 here you go.
99-01 b20z longblock
94-01 b18b intake manifold
obd1 distributor from b18b 94-95
obd1 alternator
p75 ecu
94-01 integra half shaft and axles
b series shift linkage
b series header
b series hydro tranny
94-01 integra mounts with rear t bracket.
your stock harness work for this swap as well.
By dbrooks
#224689 I love b20 swaps so much. You BETTER make a build thread. I will check it out religously :)
