- Sat Jan 01, 2011 2:12 am
#230779
i have a built gsr with 11.6comp and stage 2 skunk 2 cams and a base map that should compliment that until a dyno tune comes.
so when im driving it with a light to medium throttle load low rpms it seams to drive okay with a ocasional stumble,
however when i got meduim to heavy throttle load at any rpms it stumbles and chokes. its weird cause i have no cels so i assume its something mechanical needing a little adjusting.
does anyone have any ideas on things that could cause that?
t-belt timing is dead on i have repeatedly checked it and i hit the dizzy with a timing light and it appears good.
if any other info is needs just ask, i appreciate the help guys
