B16, B18, B20
By jgpoirier
#233907 I have an obd0 jdm b16a block that I have been told is shorter rod length than the usdm b16a. I am putting a pr3-2 head on it. My question is can I still use the b16 vtec timing belt?
Thanks,
Guy
By blk92hb
#234032 all b16a motors are the same spec
http://civic-eg.com/viewtopic.php?t=157
so you should have no problem putting on a pr3 head and running a stock b16 timing belt. :thumb: good luck with the build
By asianrob
#234071
blk92hb wrote:all b16a motors are the same spec
x2
only real difference is the pistons and cams.
By jgpoirier
#234108 Yea cause I thought that stroke length determined made it a 1.6l just as any other 1.6L. Thanks I was just making sure.
Guy
