- Fri Feb 25, 2011 7:52 pm
#240942
can i do away with the charcoal canister that the fuel line from tank evaporates into?
- Fri Feb 25, 2011 9:05 pm
#240951
The charcoal canister is an important part of your cars immission controls.
The canister stores  fuel  vapors when the engine is NOT running. The canister is filled with activated charcoal granules capable of absorbing fuel vapors.
It captures fuel vapors and prevents them from escaping to the atmosphere and then stores the fumes and recycles them to the fuel tank or engine intake for combustion as needed.
The long and short of it is that it helps to protect the environment and improve fuel economy.
I assume you want to remove it to "clean up" your engine bay. Be aware you may not pass an emission test without it. You will definitely be adding to pollution of the environment.
Why not just move the canister to a location where it is no longer as visible?
