- Fri May 11, 2012 4:24 am
#304579
Hey guys looking to get some help with my B18C.
First I'll explain the problem: While driving everything will be fine until about 2800rpm and then it will suddenly jump up to like 3300 and do a sputter/bog type thing. Then again at about 3800rpm it will do it again and jump to about 4300rpm and the tach goes all crazy and goes back and forth and then it sputters along with it. and sometimes it will do it throughout other parts of the powerband.
So far I have replaced the cap and rotor and I noticed that there was no screw holding the rotor on. I was wondering if this would cause issues.
Aside from that i really don't know where to start. I would really appreciate any tips because this problem is really bugging me and seems to just be getting worse as time goes on.
Thanks in advance
EDIT: Forgot to mention that it idles strong at 1000rpm, and I was thinking maybe the whole distributor needs replacement. Don't want to spend the money if I don't need to though. I was also thinking maybe it could be injectors or fuel filter but I don't know if that would cause the Tach to go crazy. The car only sputters when the tach starts to act up. other than that it's strong.
Thanks in advance
Check out my build thread:
http://civic-eg.com/viewtopic.php?t=22966
