- Sun Jun 24, 2012 11:10 pm
#309262
Okay, So Did my B20V swap yesterday and everything was goin good, or so I thought.
I hit a pretty big snag now. I have everything in the car, car fires up, runs SUPER RICH! as in its running a 10.0 on the AEM UGO, at all RPMS. I know rich is good but its too rich, its literly just soaking my oil.
But I have a little Valve tick, actully pretty bad.
and the car idles at 2000rpms...
So what I have done so far
-Check all sensors to make sure everything is plugged into the right one, which it is.
-timing is good
-compression umm pretty bad and I am pretty sure cuz everything us Fuel soaked that its low.
Cylinder 1- 0 (zero) Cylinder 2- 80 Cylinder 3 -100 Cylinder 4 -80
-Boost gauge reads 8-10 vacume pretty much at all times.
before it read about 22-24 not its bad, IM afraid to boost at all.
When you look at plugs, its really bad, there completly soaked, little to no carbon, Cylinder 1 is compltly soaked and looks to not be fireing.
Car runs, and sounds like its missing, I mean it has to be cuz of how bad the compression is.
Why is is throwing so much fuel in there? I am tuned for a B20 Turbo... havent had it tuned for the Vtec portion yet.
but should it be that bad?
I really need help. Ill attach 2 vids of the car.
What I added with the GSR Head is
Edelbrock Intak mani with Stock throttle body.
ARP Head Studs,
ARP Connectring rod studs
GSR Water Pump
GSR Timing Belt
OEM Head Gasket
NEW Oil and Coolant.
BWR Cam Seal
NEW Dizzy
Also forgot to buy GSR Wires, used the LS wires but replaced them as well
Did a valve lash adjustment, cylinder 1 was off on the intake side, but its adjusted now.
Can you guys please help me out I am pretty worried about this.
I also am not running a PCV Valve anymore. like the LS head has one, the GSR one did not, So I did not put it on, IDK if that could be a issue...
One other thing the Throttel body sticks so as soon as the gas is pushed thats where it stays, what could be the cause of this?
Thanks guys.
If you know what the problem is please text me at (719)433-3291 for the fastest way... cuz I am super worried.
The Vids.
-timing is good
ARP Head Studs,
GSR Water Pump
GSR Timing Belt
OEM Head Gasket
BWR Cam Seal
NEW Dizzy
Thanks guys.
The Vids.
