- Wed Jul 24, 2013 12:23 pm
#334653
I have a 94 coupe I blew out my tranny mount (passenger side motor mount) since then I havnt drove the car because it grinds but I bought a gsr tranny. My motor is a b18a1 and the tranny is gunna be put on in a few days. But my issue is what mount will go in and fit correctly? If anyone knows please let me know ASAP I'm pulling the motor mount today to try to go to a parts store to match up to see if I can find an identical motor mount but not sure when the person did the swap before that they had the right mount because it was held on by only one bolt so I'm not sure if the same mount will work because it looks like they just used one bolt to hold it before. The mount looks oem only saying this because its not a solid mount like my other two. Please help out if you for sure know what mount I need please I'm tryin to get everything in the right way not like the idiot that jus threw everything in and makin it all work. Thanks!
- Wed Jul 24, 2013 12:24 pm
#334654
Car is an ej also
- Wed Jul 24, 2013 2:05 pm
#334657
An oem integra mount will work if its a hydro tranny. There are toms of after market options out there. Innovative hasport ect ect... Hope this helps
Never Say NO To The DOMO!!!!!
- Wed Jul 24, 2013 6:00 pm
#334674
Find a mount from an obd1 integra if your tranny is from a b18a1 and it should be a perfect fit. Post feedback
- Sun Jul 28, 2013 4:33 am
#334807
Also it seems to be hitting the frame bcuz I've tried kinda forcing it to line up and it seems like I need like a longer mount bcuz motor and tranny are sitting way to high...and end up hitting frame...I'm stuck and don't know what to do going to go junk yard hopping tomorrow to see if I get lucky but still stuck with the fact that mounts just aren't lining up right ...
- Sun Jul 28, 2013 7:09 am
#334808
we need more info then. the trans came with the b18a1? is it hydro or cable clutch?
and you car is a 94 coupe?
amanti wrote:So update I still need help bcuz the mount I got wont work...it's a mount from 95 gsr integra. But the mount won't line up with the actual bracket attached to the frame...now I have no idea what to do...please help
- Sun Jul 28, 2013 4:22 pm
#334815
Okay so I found what the problem is my car was automatic now it's 5 speed...that being said I need the conversion auto to hydro bcuz it's all hydro so now I'm hunting for the mount but sucks bcuz I can't find one locally anywhere...
- Sun Jul 28, 2013 8:03 pm
#334820
gonna have to go with an aftermarket solution like this:
http://www.ebay.com/itm/INNOVATIVE-STEEL-AUTO-MANUAL-AT-TO-MT-TRANS-MOUNT-CIVIC-92-93-94-95-EG-/261066127724#vi-content
there is a method to remove the auto bracket from the frame rail and re-weld it to fit manual mounts, but a conversion mount is easier.
- Sun Jul 28, 2013 11:28 pm
#334826
So issue should be resolved ordered a new auto to hydro conversion tranny mount sucks but I had to jus hope it works when I get it next week. Thanks for all the help everyone ! I will post a pic of it out and in the car so if anyone else runs into this issue!
