- Tue Oct 15, 2013 4:11 am
#337718
Hey all, i have a question. Have a 2000 honda crv ex awd with a b20z high compression and im going to have to swap it out. Its been ticking for a very long time and i cant get it to go away. Now i know its not a civic and i didnt want to sign up on crv forum. Do you think it would be worth it to just get a cheap b20b in low compression. They seem to be cheaper than the b20z. All in all what kind of problem would i run into...would the low compression be able to handle the awd.
- Tue Oct 15, 2013 12:24 pm
#337723
You could throw in a b20b, b20z or a b18b and I strongly doubt you would notice any difference between the 3. Any of those long blocks will work, let's say you find a obd1 LS, just gotta swap over components from your current motor (intake mani, dizzy, sensors, etc)
- Tue Oct 15, 2013 2:25 pm
#337725
Yeah thats what i plan on doing. I really just need the block since nothing else is really wrong with it. Just change whatever needs to be changed when taken out. Just wanted to make sure the low compression b20s wouldnt be a problem. Ive searched but havent found any1 who did the same thing im trying to do.
- Tue Oct 15, 2013 9:17 pm
#337731
Where you getting just a block from? If you can still get B20 longblocks from most jap importers for about $550, that's the way to go for sure.
- Tue Oct 15, 2013 10:09 pm
#337735
Gonna see if local has any if not then online is best. Tiger japanese has them for 400 but ive heard bad reviews so still looking around. I just hoe i find one before this one takes a dump. Its losing alot of power for these past few months.
- Tue Oct 15, 2013 10:50 pm
#337742
Zerolift usually has them in stock
- Fri Oct 18, 2013 10:15 pm
#337823
why not pull the head and have it gone through? a lot cheaper than swapping a new engine in.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Mon Nov 25, 2013 5:29 pm
#339332
the b20's have solid lifters i found out, that's why it ticks. if valves are correctly adjusted in spec they will tick. it's once they go quiet that they start burning valves. you will notice the 20 hp difference between the b20b and the b20z. the jdm b20b from the 98-01 V's are the same engine as the b20z in power numbers
- Tue Nov 26, 2013 11:40 pm
#339372
They dont actually have lifters... but they're design is no different than an LS... in fact its exactly the same.
- Thu Nov 28, 2013 5:42 am
#339437
They are called hydro lash adjusters that "run" off of oil pressure. High mileage engines you will notice that ticking noise even after adjusting valves. They can easily be replaced with a new set (if you're gonna take em out don't buy used or even low mileage ones). This is what they look like
Yeah I have a 4dr, no you can't have a ride.
