Subaru WRX 440cc injectors
Mon Dec 14, 2015 7:05 am
by brolly
Hey guys I would like to know if one can use a WRX 440cc injectors on a B18c?
Will they fit on the stock fuel rail?
I would also like to know if I need to upgrade the fuel pump or I can just a fuel regulator t
I am assuming that a chipped p28 or p30 with crome can control these Injectors normally
Re: Subaru WRX 440cc injectors
Mon Dec 14, 2015 2:34 pm
by HeikDiesel
Why would you use WRX injectors? I would assume you can get some cheap or free? Never heard of anyone using them, although a common one is Acura RDX injectors, people make adapters and they will work with a B18C. Also, what is your setup. Hard to tell you if you need to upgrade your fuel pump if we have no idea what you are trying to do.
Mon Dec 14, 2015 3:09 pm
by brolly
I have a set of these injectors that was going to use on another project . My setup is a stock b18c and soon going to supercharge it (JRSC kit) and i don't want to use the FMU provided with the kit.
When not using the FMU it is suggested to use a 440cc injectors when using this supercharger kit
and when i saw this DYI
http://civic-eg.com/viewtopic.php?p=296990I thought that i can leave these injectors stock and use them in my setup
Tue Dec 15, 2015 3:56 pm
by HeikDiesel
I used 1000's on my setup. Granted they were only at 50% duty cycle but they idle like stock so why not? I would think depending on power you would be close to maxing those 440's out. If it was me I'd just get a set of ID 1000's and call it a day. I realize that may not be an option due to money but I don't know much about those injectors so I can't offer any advice there.
