B16, B18, B20
By civicboy
#63109 HI, i have been having some problem with the eg since i did b16a2 conversion, some fuses were blown, had wrong driverside headlight loom, but now i have sorted everything out, and now the problem is when i try to start the car all the cluster lights just go out for about min or so, there is fuel pump noise and then when i start it, it clicks aswell but then the whole custer lights just go off, does anyone think that it might be some earth problem,
i have checked my starter motor it works, charged the battery for a full day, all the plugs are pluged in the right place, the looms are perfectly alright, the ecu is fine, there are no codes at all,
help me out please, i will realy appreciate it, thanks Amer
By mage182
#63124 I would say it's the grounds. Check all of them on the engine to make sure they are tight and that there is no corrosion on them that would hinder their performance.
By civicboy
#63241 installed the buddycub condenser today, and the car started first time, everything is running fine, water is circulating but the fan is not coming on, thats the only problem which needs sorting out, Amer
By a_CoUpE
#63248
civicboy wrote:installed the buddycub condenser today, and the car started first time, everything is running fine, water is circulating but the fan is not coming on, thats the only problem which needs sorting out, Amer
for the fan, take the plug for your fan switch and cut it and splice the 2 wires 2gether the fann will stay on all the time but it works! :thumb:
By civicboy
#63262 the fan works now but need to know that where does the map sencer hose go on manifold or throttle body, as my map sencer is on the bays firewall, Amer
By a_CoUpE
#63277
civicboy wrote:the fan works now but need to know that where does the map sencer hose go on manifold or throttle body, as my map sencer is on the bays firewall, Amer
the mp sensor can go anywhere i believe just make sure there is a vacume hose that goes from the sensor to somewhere on the mani.
