- Fri Feb 01, 2013 11:45 pm
#325437
The OBX ITB's are not one of the best Products OBX has made, the hardware used to make them is garbage. The casting is very rough and nasty. If you want the OBX's to make good power on any B series, they need to be opened up. And that about puts an end to their price point, TWM's start at 50mm and go up. The OBX's are 48mm tappered to a 45mm, according to Endyn, thats not even big enough for a mild B16.
thenewvessel wrote:I was looking into these too but the power gains arent as significant as you would expect. It's cheaper going with a mild cam, head work, and TB honestly and you'll be pushing more power.
true, but you cant replicate the throttle response the ITB's produce. if the motor is built and parts are selected that will work with the ITB's, they can produce some serious power.
thenewvessel wrote:Plus ITB's have always been a pain to tune and are extremely sporadic under temperature/weather changes.
mine work perfectly fine. originally tuned in late summer early fall temps in the lower 60's (id guess), and recently driven when it was about 40 degrees outside... no issues with driveablilty. Please stop while youre ahead when making ASSumptions.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
