- Tue Sep 16, 2008 2:36 pm
#70017
93hatcheg wrote:k i found the issue
my idle control valve isnt plugged in and the map sensor line had a crack in it. im going to fix these tommoro. however can anybody post me a pic of the plug in the wire harness that goes to the icv. also if the p28 doest run it correctly without being chipped what is a good AFFORDABLE chip. i dont want anything that will mess up my engine at all.
- Option 1: Get a Stock B16 Ecu
- Option 2: Take your car to a Tuning shop, Ask Around in your local area for good ones. One of the Best Tuning places locally here will Reflash a chip to a stock B16 Basemap for you. However you will have to you ECU Chipped already. If not they charge $250 to Chip and Tune your car.
I Recommend Option 2. Dont buy chips online, you Want one tuned to YOUR engine. a Basemap is good, a Tuned Map is even Better.
