B16, B18, B20
By la0boi4oi
#74629 I got a 1992 eg hb gsr swaped i am wondering if i get a full cat back for my 92-95 hb will it meet up with the cat or header on my gsr swap? since i got a b-series in it? :? well i am looking to get a apexi ws2 full cat but in need of help will i need to weld nething put nething in between or cut? well :eh: hope i can get some question and help :woot:
By sdots
#74657 Well first of all just make sure your buying a catback which is made for your hatch and is for a B-series.
The exhaust will start from after the cat if it's a cat-back.
Anything starting from your down pipe on your header is called a de-cat, thus eliminating the catalytic convertor.
If your buying the Apexi ws2 it will be bolt on, no welding or cutting should be involved at all.
#74820 No, it will not just bolt on. You will need to have a muffler shop or compitant welder modify it to fit. Its either too short or long. I cant remember which.
By la0boi4oi
#74969 thanks for the info well i got 4-1 header going into a carsound cat with the whole catback i am thinking the exhaust can be extended to the catback if its too short or cut if its too long
thanks :thumb:
By la0boi4oi
#77093 It ended up being about 6 inches short, so i ended up getting it welded 3 inch on both sides of the cat with flanges but sounds LIKE A CHAMP! quiet 8)
By sneepereg
#157400
la0boi4oi wrote:It ended up being about 6 inches short, so i ended up getting it welded 3 inch on both sides of the cat with flanges but sounds LIKE A CHAMP! quiet 8)
ahhh so jealous thats sick pics???
