B16, B18, B20
By cukakula
#79226 hi everyone..... i'm planing to upgrade my camshaft soon and i still spoilt for choice.... hopefully you guy can be able to share some opinion .... here's my motor setup...
b16a2 with ctr pistons
port polish head
type r valves
jdm ax limit headers
spoon ventuli plate....
there are several cams that i'm interested.... brian crower stage3, skunk2 pro stage3 and buddyclub stage5.... i've tried buddyclub stg5 in my friend's rex b16a... i can fell the power when the car is pulling on high reving... the cams is making wonders.... on the other hand i've heard feedback from some of my friends that brian crower stg3 cams are not making plenty of power... can anyone verify it???? hope to hear from all of you....
By flyinryan122
#79526 My little bro ran the brian crower stg3's in his b16a with ctr pistons. Car was sooo much fun. but PRICEY. :o
#79540 ive got Toda Spec Bs. They were very nice in the last motor!
By cukakula
#79547 you should try toda c.... the power dosen't die when you pull till 8,500 rpm... can still go beyond that... b16a with ctr piston...
#79550 I would love the C's but I have the B's already so Imma stick with them.
#79557 Is your entire valvetrain upgraded?? If not, I'd do that before cams.
By cukakula
#79588 yes of course.... planing to replace the cams and dual valve springs without the retainers.... so will it be safe to use oem retainers instead of aftermarket??? i notice that aftermarket retainers tend to wear off easily in a short period of time and has short life span.... couple of my friends blew off their motor because of aftermakket retainers failure...
By 0p71mu5pr1m3
#79596 I believe most of the higher stage cams come with recommendation of upgrading your entire valvetrain, including retainers. I highly recommend the Bisimoto Cams. A little pricey, but if you call him and talk to him he'll work with you and basically grind your cam to spec based on what you want to do with it.
By cukakula
#79677 Bisimito cams ok.... customize will be great.... i've heard last time that rocket motorsports able to customize cams as well.... What about Endyn cams??? thank for your info 0p71mu5pr1m3....
#79679 Endyn will make them the way you want them too.
