By id3379
#155392 It should.
By Dippin_EG
#155409 I would check on whether you need to change from a 3 wire IACV to fit an auto, which i think uses a 4 wire IACV. dont know for sure though.
By suspendedHatch
#155439
Dippin_EG wrote:I would check on whether you need to change from a 3 wire IACV to fit an auto, which i think uses a 4 wire IACV. dont know for sure though.
Thats on the EK. EG doesn't have this issue.
The intake manifolds are the same. The throttle bodies are different between auto and manual.
By d4rk13l4de
#155497 so i will be ok to just swap the throttlebodys?
By Classiccarsrule85
#155504
d4rk13l4de wrote:so i will be ok to just swap the throttlebodys?
yepperz throttle bodies like suspendedhatch said are the only difference on our egs...
By d4rk13l4de
#155528 thanks again guys, civic-eg in my opinion is the best for info!! you guys all rock
