By JDM FERIO BOYZ
#164586 ok i replaced my clutch, pressure plate, and flywheel new and im still having problems with whinding out. my car takes so long to go in 1st gear and if i give it to much throttle it revs out??? i just bought a slave sylender and a clutch master slyender. think that may be it?
By platnuim86
#164623 did you bleed it ?
By JDM FERIO BOYZ
#164629 thats the thing. when i bleed the slave it ran hard and perfect. but now its acting up again 2 days later
By platnuim86
#164705 cheak the rubber lines for leaks have a buddy ingauge the clutch a couple of times and see if it leaks or if the slave boot is cracked or torn
By JDM FERIO BOYZ
#164846 pumped it, i heard a lil hys of air thats it. no clutch fluid leak though and no cracks in the boot
By platnuim86
#164855 do you have any leaking from the bell housing
By JDM FERIO BOYZ
#165006 nope. now is it bad for me to drive the car. its like a must to take my girl to work. but it keeps whinding out. itll move just EXTREMELY SLOW and bad. now is that messing up my clutch/pessure plate/ and flywheel?
By drago742gtr
#165012 is there any oil in the trans ?
By biggnutz123
#165015 So it sounds like its trying to engauge but its not ingauging full just an idea but iv herd of plastic pices inside the pressure plate they use for packing and shipping, just an idea. another idea is chech your fire wall and your clutch pedal assembly for broken or cracked/bent piceses. We acualy did a clutch on a toyota the other day and that was the main problem that the cluch pedle assembly was actualy cracked and bent.Just a few other ideas for ya good luck!
By JDM FERIO BOYZ
#165104 yeah theres oil. it cant be the clutch being bent. when i bled it the other day it worked fine. chirpped and everything. but now its bad again
By sickvtec
#165270 may i know how did you bleed the clutch? how do you know its fine? just checking :? do you have to top up your clutch fluids ? snap some photo and we all may see what is the problems with it dude...
By JDM FERIO BOYZ
#165346 me and my boy did it. he works at honda and i know enough. so i know we did it right. i pumped the clutch and shit. he bled. not that hard to bleed it. thats why i dont know why its doing it. what would i take pics of?
By JDM FERIO BOYZ
#168394 WOW!!!!!!!!! i feel so dumb. my clutch resivoir cap's ring under the cap had tear's in it. so it was getting air in the lines. fixed it and now everthings fine. i feel like an idiot
