By Lt.DudeEJ1
#172240 not to sure if this is the right place to put this but oh well
my clutch pedel goes realy soft and i can barely start my car sometimes like i can push it in and it will go almost al the way to the floor without engaging alls i can think is wtf
#172243 how's the fluid level?
Next look at your master cyl and slave cyl, you may be getting air into the lines. A bad/leaking MC or SC will do that.
Look for fluid coming out of them both. Keep in mind the lave cylinder may be leaking inside the rubber boot and the master cylinder may be leaking on the inside of the firewall. :thumb:
By Lt.DudeEJ1
#172682 i know theres a leak it started when the weather got frigid i know theres fluid coming out around my left fender because theres always a small puddle right behind me tire i carry a bottle of fluid with me now its kinda annoying to have to pump my clutch at every stop light lol
By JUICE
#172684 sounds like the slave cylinder. might wanna look into it before it leaves you stranded at a red light.....
By drewbuisness
#172688 Its hard out there but it aint worth making the damage worse so check it out dude 8)
