By dbrooks
#180268 This is weird and something I've been trying to solve for awhile now. My 93 eg will overheat in stop and go traffic if the heat is not on. So basically, when I'm in traffic my heat has to be on or I will overheat. I've already changed the head gasket, but nothing. I'm wanting to get this fixed by summer!
Thanks guys!
By ikon
#180273 check ur coolant level. if that doesnt fix it then replace ur thermostat.
so u have no leaks?
By dbrooks
#180274 Nope no leaks at all. I'll check my coolant first thing tomorrow morning. It's just weird that it doesn't overheat while the heat is on.
#180276 Air bubble in the coolant system. :? It'd be a nice easy fix. :thumb:
By TrailerTrash
#180284
ChicagoMike wrote:Air bubble in the coolant system. :? It'd be a nice easy fix. :thumb:
cant hurt to try!
http://www.hondacivicforum.com/forum/sh ... hp?t=41650
http://www.rebuiltautoengines.com/honda ... icles.html
By dbrooks
#180302 Yeah I actually replaced the radiator and the head gasket. I'm gonna try the thermo.
By Apexracing
#180314 coolant temp sensor :?
By acereiEG
#180986 +1 on the radiator fan.
if the temperature rises in stop and go traffic, you just aren't getting any air to your radiator.
Either the sensor for that is gone (about 25$ and 5 minutes to replace)
OR
the fan itself is gone.
try running the car for awhile to see if the fan will turn on (once it passes half way on the dash heat indicator)
if fan does not turn on: sensor is not working or fan itself is broken.
gooooood luck.
By dbrooks
#181633 It just overheats ifit the heat is turned off. But I fixed it. Wiring problem with my cluster. Thanks for all the help. I really appreciate it! :)
