By kel
#185645 Can anybody help me find part numbers for a jdm d15 rebuild. or any good threads on building a jdm D15 engine.
Thanks kel.
By d-mon
#186410 because they are jdm, replacement pistons and crankshaft are not available
many of the other parts are the same as d16z6, however i recently discovered the rings rings are the same as d16y7/8, not d16z6/a6
rod bearings = d16
main bearings = d15
thrust berings =d15
timing belt = vx
some more helpful links:
http://www.d-series.org/forums/naturall ... icial.html
http://www.d-series.org/forums/general- ... c-faq.html
By eg84dr
#186845 d15b :woot: :woot:
if you want a killer turbo motor get the kit from fj distributers
i havnt seen anyone run that setup yet but i know it would be a killer motor for a 1.5 :thumb:
good info d-mon btw
By kel
#187231 Thanks for the info guys :thumb:
By forcefedEG
#187389
eg84dr wrote:if you want a killer turbo motor get the kit from fj distributers
a friend bought one of there kit for his z6, and the car is pretty impressive for him not running a pile of boost... :thumb:
