By jayEGR
#201019 ok guys i found another issue thats fuckin up with my car :x alright so every time iam drivin and press the gas like after i say 4,000 rpm it starts makin a nosie then when i let off it stops even if iam in high rpm , but one thin is there a bolt thats lose on the head iam pretty sure its not that becuz when i press the gas or not it should keep goin it sounds like its comin from my cams , dnt know if i nee dto re adjust or maybe somethin i dnt know it fuckin sucks its my daily driver any opions on d series guys , some input ,please :cry: :cry: :cry: :cry: :cry:
By Classiccarsrule85
#201024 well is it a grinding noise or is it a knocking noise?
Knocking more than likely a rod / spun bearing,
grinding something in the head .....
By jayEGR
#201026 no grinding more like if the engine was gargling lol but it sounds like its comin from the head it self ,i knw what knockin sounds like an its not that it sounds more like quick taps but sounds like its comin from the top of the engine :? :(
#201034 well yea i dont recommend doing this fro a long period of time but take your valve cover off and listen i guess would be your best bet to see what it might be look for wear in the head things that arent smooth etc....
By jayEGR
#201036 alright ill see wat i can do thanks man
By jayEGR
#201638 ok so if i take the valve cover of iam have to rev it up to 3-4,000 rpm should i still have the valve cover off doin this process, i need some help cuz iam sure its comin from the head now :cry: :(
