- Thu Jan 21, 2010 5:17 pm
#170053
three od four days if you only work for about 2 or 3 hours each day if you got a buddy or 2 that can help you can swap out a d series and swap in a b series in about 6 to 8 hours depending on if its vtec or not
- Sun Mar 14, 2010 9:27 pm
#181252
I'm gonna do this soon! I'm pumped
- Sun Oct 10, 2010 5:56 pm
#217752
^^ Hmotors is the only online source that can be safely recommended. they're also close to the priciest...
- Wed Jul 06, 2011 4:12 am
#262496
does this also include swaping the tranny since it wasnt included in the list?? im a noob if ur asking lol
- Thu Jul 07, 2011 2:41 am
#262608
yes you must have a b series trans for a b series motor b trans are bigger than d series unless you get the conversion plate and a d to b swap should take like 3 hours thats how long it to me and i was alone
EJ2 FoReVeR. My car is a whore
build thread http://civic-eg.com/viewtopic.php?t=18655
#1 COUPE CREW MEMBER
- Fri Dec 28, 2012 5:12 am
#322888
my 92 lx had it wired up to shock tower as well...it threw me off cuz when i went to the ECU to pin them in the ports were taken already...and my car was completely stock
teal_dx wrote:true, only the 92 hatchbacks had the wiring for vtec solenoid & oil pressure sensor ran up to the passenger side shock tower. (correct me if I'm wrong) and the EX/Si had the full wiring & sensors. Any other years and you'll need to pin the wires into your ECU.
EG8 Build: http://civic-eg.com/viewtopic.php?t=20985&highlight=
EK Build: http://civic-eg.com/viewtopic.php?t=257 ... highlight= SOLD
#10 of The Civic-EG.com Ferio Squad
- Fri Jun 27, 2014 12:42 am
#346781
could someone compare the level of difficulty between b16a2 swap and b18c into an eg
- Fri Jun 27, 2014 10:47 am
#346793
In all honesty they both are b series vtec motors, their difficulty is going to be almost identical.
If your lowered, the b18c does sit a little lower, so the endangerment to your oilpan is increased with the 18c. Really type r swaps and other swaps in eg's you can crank out in a good weekend if its your first time. Once you've done it a couple of times, about 4-8 hours for a swap is a common procedure.
If you are a dx, cx, vtec would have to be wired in, but i did it on my 88 civic sedan and it was cake, done it on tons of locals cars as well. super easy.
1988 civic sedan - granny car MPG'S http://civic-eg.com/viewtopic.php?t=27768
1994 civic hatch - BECAZ RACEKAR http://civic-eg.com/viewtopic.php?t=27511
- Fri Jan 16, 2015 3:34 am
#351095
ok so I like this thread! read through it but one thing id like some one to touch base on is the power steering. I bought my car with a b18b1 already swapped into it and there is no pump or lines or reservoir... so my question is do I use Integra pump lines and reservoir or eg pump lines and reservoir? thanks in advance and if this isn't the place for this post please let me know Im new to the online fourm thing..
B18B1-EG-SEDAN
Bought not built haha in the process of rebuilding to my specifications.
- Fri Jan 16, 2015 4:37 am
#351097
I can answer that. I've got a B18C swap that maintains power steering and A/C. I used all the factory power steering parts on my 92 and it's been perfect so far.
b18b1egsedan wrote:ok so I like this thread! read through it but one thing id like some one to touch base on is the power steering. I bought my car with a b18b1 already swapped into it and there is no pump or lines or reservoir... so my question is do I use Integra pump lines and reservoir or eg pump lines and reservoir? thanks in advance and if this isn't the place for this post please let me know Im new to the online fourm thing..
- Fri Jan 16, 2015 11:33 pm
#351117
Awesome thank you! I am going to the junk yard this weekend to get a pump and lines. we have lots of egs but no integras
Leppy wrote:b18b1egsedan wrote:ok so I like this thread! read through it but one thing id like some one to touch base on is the power steering. I bought my car with a b18b1 already swapped into it and there is no pump or lines or reservoir... so my question is do I use Integra pump lines and reservoir or eg pump lines and reservoir? thanks in advance and if this isn't the place for this post please let me know Im new to the online fourm thing..
B18B1-EG-SEDAN
