- Wed Nov 03, 2010 12:01 am
#221248
Just swapped in jdmb15 in my 95 coupe
i took out a smoking d16z6
and found this motor in the junkyard
guy said it ran great no smoke no knocks
swore by it said his empoyee wanted to buy it
swaped motor this weekend
i used the old Intake mani from the z6
and dizzy. swapped the vtec sol to
Fired car up, idle surges like a stuck IACV
blows white smoke ( just like the old motor i swapped)
let it run and try to bleed the coolant so it will idle ( major exhust leak between the cat and header. and i wanted to not piss off the neighbors)
never stopped surging and when i turned off the car coolant spilled along the right side of the block, down by casting numbers, and all along the back on top of the tranny.
cannot locate leak
is it possable that i have a wrong intake gasket? or bad intake gasket and its sucking coolnt into the manifold before it reachs the idle control valve.
and would that explain it leaking when turned off?... im thinking the coolant is expanding when i turn it off and leaking out a poorly sealed intake?
cannot locate leak
