By foxgearshift
#252487
Gustavo wrote:So i temporarily clampped down my distributor 2 the cam cap so i can see if my hatch would start n this is wat it did. Wat can it b? Im gonna check the timing later.
did u check if u have spark??
check the distributor before u go to the timing my freinds had similer broblem his rotor screw was out !!
By Gustavo
#252497
I will check later n see.
By LaosToaster
#252515 i bet its the distributor. but since u took out the head and all that check ur mechanical timing then ur ignition timing using a timing light. if everything checks out and still no start, check ur firing order. just to make sure ukno :thumb:
By Gustavo
#252528
LaosToaster wrote:i bet its the distributor. but since u took out the head and all that check ur mechanical timing then ur ignition timing using a timing light. if everything checks out and still no start, check ur firing order. just to make sure ukno :thumb:
I'm gonna try n get a timing light. N will try 2 do wat u suggested.
By foxgearshift
#252763
Gustavo wrote:I need help finding where i can buy a timing belt tensioner spring. Where can i buy 1?
http://ecx.images-amazon.com/images/I/41xHuOJXwXL.jpg
http://cgi.ebay.com/ebaymotors/OEM-B18- ... ccessories
By 1ACarlos
#252779 You can also try partfinder.com.
By Gustavo
#252808
1ACarlos wrote:You can also try partfinder.com.
Thank u. :thumb:
By Gustavo
#253117 Well im making a list of wat i need 2 buy/order for my hatch. N i need 2get this but idk wat it's called. Is it a cam cap? It is where the distributor bolts on to. The broken piece is on top of the vc. N once again where can i get it? The auto parts store here suck n they didn't even have it.
#253119 junk yard
it should unbolt
By Gustavo
#253120
94_jdm_ferio wrote:junk yard
it should unbolt
Our junk yard here suck. There r like no Hondas n if there is they r SOHC.
By Gustavo
#253508 Well part of my dream is coming true :D I am painting my hatch Championship White!!! My friend n I started 2day. This is how she sits right now. We will continue 2morrow n finish the body work. Here r some pics.
By orangeEG
#253515 Geez you went balls out on stippin it down eh haha, Doors off and all and still left the tail lights in haha :thumb:
We just painted my buddy's integra... Shit load of sanding haha
By Gustavo
#253530
orangeEG wrote:Geez you went balls out on stippin it down eh haha, Doors off and all and still left the tail lights in haha :thumb:
We gonna take everything off. Tail lights, headlights, doors, bumpers, hood, fenders, side skirts, hatch, hatch window, anything that can come off is coming off. n we r also painting the whole inside. The seats r already out n the floor is being prepared 2 paint. :thumb:
