By Civvy
#254969 Is there much can be swapped for improvements with this engine it seems rather unpopular: i've owned one years back and they were great apart from a broken conrod.
A perfect swap for an EG3.
I wonder if the dual carbs could work on the 8/9 thus making use of the higher cr
#255577 There was a D16z1 engine available in other countries. It came up once before on this forum and I also thought that the poster meant D15z1.
It must not be common, it's not even listed on wikipedia: http://en.wikipedia.org/wiki/Honda_D_engine
edit: found some info on the D16z1
The same configuration of engine, with matching power output levels, (120ps at the same rpm), is also available in what can best be described as 'lesser' markets for Honda. This engine then often powers the top models for that market. An example is the Malaysian domestic line-up, which for the previous and current generation has a Honda Civic 1.6EXi which is powered by a 120ps 1.6l SOHC PGM-Fi engine but coded as SM16A. Similary, for the equivalent EF-generation, the Malaysian domestic line-up has a top model, the Honda Civic 1.6EX which is powered by a 105ps 1.6l SOHC Dual-Carb'ed engine coded as D16Z1. There is a distinct possibility that these engines are localised export versions of the 'master' JDM ZC engine.
from http://asia.vtec.net/topics/zc.html
By Civvy
#255578 Thanks Teal.
