- Mon May 23, 2011 4:43 am
#256406
well first off its not my car thats doing it its my friends ek coupe with a b18b1 swap with a pr4 obd1 ecu.
heres what ive done with no luck
cleaned the fiv
replaced the iacv
bleed the cooling system
replaced pcv
tried different ecu's (different pr4 and a obd2 ls ecu)
adjusted idle screw all the way in
checked thottle body
replaced throttle body gasket
i have no idea what is causing it and the only code it pulls is 41 main o2 sensor heater
cleaned the fiv
replaced the iacv
replaced pcv
EJ2 FoReVeR. My car is a whore
build thread http://civic-eg.com/viewtopic.php?t=18655
#1 COUPE CREW MEMBER
