- Thu Jun 02, 2011 4:40 am
#257806
Wiring update!
Whenever it comes to wiring, I always think twice. Not really my favorite thing. I made up a meter loom extending my 4 wire o2 sensor that I cut from my EK harness.
I've been running without an o2 sensor for 6 months now. Hopefully it doesn't do any damage.
I basically done my own research. If I fuck things up I can only blame myself. Most info I got was from honda-tech. I practically stared at this bit of paper for a week, double checking and making sure it was right.
I really wanted to wire in the o2 sensor on the shock towers in the engine bay for that OEM look but it's too difficult and hard to find info on. So I wired it directly to the ecu.
Also
- removed that rectangular plastic thing protecting the harness
- separated and zip tied the harness
Went from the Mugen ECU back to the factory EK P2T ECU with adapter
I did a cel code check and got no more codes for the o2 sensor. Only code I get is code 20 which is bad earth/battery? Apparently it's a common problem, a code which is hard to get rid of, not to worry apparently.
Before I use to get 350km from a full tank. Hopefully it will be more now that my engine is now running 100%
