By xjm92x
#266273 So i redid my y8/b7 miniswap because after the first time it was not running right and ever since the first time i had to keep jumping my battery because it would die and now i tried to start my car and i got nothing , i have fuel and air but no spark also starter does not click or crank cel also comes on i used the port under the dashh and i gues the cel code is 10 because the light stays on i think its the battery but most of the electrical stuff turns on radio, lights, ect i also removed the a/c and auto cruise box from under the hood.
Sorry for the long post. Any ideas wat can be wrong
By undeadone069
#266280 it is a electical problem somewhere right. maybe check fuses/relays? just trying to help srry still learning myself. :?
By xjm92x
#266282 Think it is too maybe the battery fuse blew i keep hearing a click from under the shift box
By xjm92x
#266283 Im wondering if since i removed the auto cruise and a/c pump and hoses was i suppised to remove ceryain fuses and the auto cruis computer?
By RWMIII
#266289 well a code 10 is a IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor.
if the battery fuse blew then check your wiring to and from the battery, starter, and alternator. make sure all grounds are good, and no positive cables/wires are touching any grounds.
By undeadone069
#266315 is it a 5 spd? my 92 is a auto and i once noticed a wierd clickin when i turned the key on and hit the break then i realized it was the lock for the shifter lol idk if that is ur click though?
By xjm92x
#266317 Its auto
By xjm92x
#266432 Well since i could not get the car to start my mom took off my insurance so i guess i shall part out
