By asianrob
#282159 i seen the difference when i dyno'd my K20
By mADmAN
#282259
carbonfibreMY wrote:Good news guys my project is coming along..
Thanks for all the feedback but having the filter near the bumper is a nono in where i live as flash floods are a daily headache ! :thumbdown:
Will be sticking with the original plan
This is what im gonna be using
- broken EG signal lamp ( right side ) coincidentally the shape fits the curve im gonna attach it to my bumper from the inside on the right side. ( my ride is RHD )
- aluminium sheet to make a heatshield in the bay for the filter ( any suggestions on thickness wise to prevent flexing ? )
- a big hose
Will be putting up some pictures soon if i have time busy at the workshop these days..
Anyways @madman and everyone here , do BPI stacks really work ?
take pix and post them up here on in zth... i wanna see n mebbe copy ur idea if its feasible heheheh
the stacks...from the post above and also from the other posts online....yes they do.
By suspendedHatch
#282806
asianrob wrote:i seen the difference when i dyno'd my K20
How did you get a forced air effect on a dyno? Dyno fan?
By asianrob
#282844
yep the only way lol other than that it probably wouldnt work if i remember right with open headers and a bag of ice on the intake mani we got a good 10ish hp extra hp l
came out to 209 hp @ 156lbs
with RDX Injectors and RBC could have made another 10ish hp. but we dont own the car anymore.
By mADmAN
#284194 i guess ill have to delay/scrap my DIY AEM CAI plan...
coz THIS has been a common sight lately... way too common.
and there isnt any signs of it going away anytime soon
By Apexracing
#284216 Wow thats awful i have a friend thats from the Philippines, and another that moved back home there. Wish you and your family all the best, and i hope this crazy weather cuts you guys some slack.
By suspendedHatch
#284732 "with open headers and a bag of ice on the intake mani"
Hrm. Multiple variables in this equation.
In the the article I read they had put pressure sensors on different parts of the front of an EG, and they also had little strings stuck all over the front end. The result they found is that the fog light hole is a low pressure area and that you're better off plugging it and having your filter behind it. Or gutting the headlight, but then you have to take the pipe length into account. Length and diameter of the pipe is what determines the hp gain while air temp has very little relative effect despite the "cold-air intake" moniker.
The air doesn't strike that area, it's flowing sideways from the center. Air flowing sideways in front of a hole will give you lower than atmospheric air pressure. I'm willing to wager than the inlet in the pic above this post is also sucking air away from the intake. The high pressure areas are the headlights, the radiator, and the base of the windshield.
You can call BS on me because I don't have the article. I want to say Super Street but I could be wrong. The reason why the conclusions stand out in my memory so strongly is because before learning this, I had cut away the plastic between the slats in the fog light hole to expose the air filter. I felt pretty stupid after reading the article, and later I swapped the bumper when I was about to paint the car.
By asianrob
#284735 [quote="suspendedHatch"]"with open headers and a bag of ice on the intake mani"
i just had a short ram with a V stack.
no holes cut for the intake. but had big fans blowing and the air temp was already cold out side. like 60ish since it was december. but being that it only made 209 while i seen other people with filters make the same power you could probably say the v stack could probably have done nothing or something.
all my K series was:
z3(06 si short block)
Type S head
Kpro
K swap headers it was a Tri Y with an extention
but no i never cut the bumper for an intake. i did for foglights tho.
