- Wed Oct 17, 2012 1:01 am
#318056
I bought a new throttle body and await its arrival. Update will follow after I put it on.
They call me Mr. Brown Rice
d-mon wrote:any check engine light? is the idle surging?
clean your iacv? clean the fitv?
EJ1_MK wrote:Would check the TPS or throttle position sensor, if it is out the car will run horrible. and if you put a new throttle body on it came with one. There is a voltage reading that it should be in when it is closed and fully open.
Check your codes first and see what that comes up with.
BrownWolph wrote:EJ1_MK wrote:Would check the TPS or throttle position sensor, if it is out the car will run horrible. and if you put a new throttle body on it came with one. There is a voltage reading that it should be in when it is closed and fully open.
There are no codes related to this issue.![]()
And if the TPS was the issue wouldn't the idle act wonky the whole time and not for just the first 5-6 mins?
EJ1_MK wrote:BrownWolph wrote:EJ1_MK wrote:Would check the TPS or throttle position sensor, if it is out the car will run horrible. and if you put a new throttle body on it came with one. There is a voltage reading that it should be in when it is closed and fully open.
Ok well from your original description was hard to tell what you where asking.
So if I have this straight it idles normal but falls low and comes back up for the first 5 or so minutes after the car is started cold correct?
Also the cable that comes off the throttle body that runs to the trans does it have tension. That is what they call the down shift cable.
Automatics are a pain when they start to have issues like this because of how all the system interact. Have you checked the coolant level?
It sounds to be the fast Idle valve that is directly under the throttle body there is a little piece of rubber in there if it gets knocked out of place that it will surge. If you replaced the throttle body then you would have had to lost some coolant there might be air in the system.
BrownWolph wrote:EJ1_MK wrote:BrownWolph wrote:EJ1_MK wrote:Would check the TPS or throttle position sensor, if it is out the car will run horrible. and if you put a new throttle body on it came with one. There is a voltage reading that it should be in when it is closed and fully open.
1) Correct
2) It does but it's not guitar string tight. Should it be?
3) No, I will tonight
4) I did replace the TB and I did lose about a 1/4 cup of coolant. How would I get the air out of the system?
Thank you!
