- Wed Jun 18, 2014 3:55 am
#346530
Andre3th0u wrote:I am planning to sell my drum set for new suspension setup and catback exhaust. I am gonna get full coilovers but I wanna go lower. I've been reading into drop forks for the front but just curious on how I can drop the rear more also. Let me know guys. I want her slammed
slammed? get bags lol
you could look into drop spindles and modified trailing arms. like these:
spindles ^
all they do is move the wheel hub up on the spindle or trailing arm to lower the rest of the car.
only gives you about 1.5-2 inches of drop and you run the risk of smashing your oilpan, and theyre really meant for showcar use not street use. they also usually arent tested as far as durability goes.
if you wanna get low without bags, get some cheap stuts and some coil over sleeves.
alot of the miata guys who are slammed and static are using racelands. no sense in destroying an expensive set of coils to go super low.
also, i extremely recommend extended top hats. keeps you from bottoming out as bad.
my setup, and i was scrapping subframe on flat roads at one point, was koni yellows with ground control coilovers and extended tophats.
ride was harsh, but i could go even lower than i was.
koni/gc combo can go really low. check this video out:
http://vimeo.com/37885858
its an integra, but its pretty similar suspension.
good luck with the hunt for slammage!
sorry for the novel lol
